NI TestStand
Teststand engine did not finish its cleanup procedure
I have a VB.NET application that creates an instance of the TestStand engine and then makes two calls to the GetTestStandPath method. That's all. When I close my application I get an error message saying, "The TestStand engine did not finish its cleanup procedure."
How do I make that go away?
I have tried calling Shutdown and waiting for the UIMsg_ShutdownComplete message. That doesn't work.
I have tried calling GC.Collect and GC.WaitForPendingFinalizers after doing that. I still get that error.
Any thoughts?
(2,637 Views)
Hello Skeptical,
Did you found a solution for your problem in the meantime?
Best Rgds
MAGL21
(2,411 Views)
What I did instead was to  simply call the .NET method Environment.GetEnvironmentVariable("TestStandPublic64").
(2,407 Views)
Thanks for feedback -> I found a solution for my case.
May this can help if someone has the same Error in future.
Solved: Re: How to release components correctly via Api (especially Users.ini) in vb.net - NI Commun...
Best Rgds
MAGL21
(2,397 Views)
