NI TestStand
Teststand error handling Option
HelloCan I turn Off the error Popup without:
Ignored the error,
Terminated the test program
Tphan
Message 11 of 17
(3,064 Views)
Hello Thanks
The key is the "RunState.Caller.RunState.ErrorReported = true"
This will turn off the Dialog box
Message 12 of 17
(3,063 Views)
One thing is I still not see the way how to tell the sequence not to stop after accepted the error.
If I set the var to :
RunState.Caller.RunState.ErrorReported = True
The Popup disappeared,   however,   the sequence also terminated.   How to make the sequence continue to run?
Tphan
Message 13 of 17
(3,060 Views)
Here's an idea. You can do:
Parameters.Step.Result.Error.Occurred = false
But this will make the sequence no longer have an error status. To fix that you could store the fact that you got an error in a global or in a variable you create programmatically under RunState.Execution.RunTimeVariables. Then, you could do one of the following:
Either
1) Add a step to the end of the cleanup of your top-level sequence than conditionally generates a runtime error based on the variable. And SequenceFilePostStepRuntimeError should be setup to not do anything for this step
or
2) Modify the process model to treat the variable being set as equivalent to the execution having an error state.
NOTE: You will have to reset the state of the variable before each uut either in the setup steps of the top-level sequence or the process model.
-Doug
Message 14 of 17
(3,048 Views)
Yeah,
I got that.  Alll of this trouble just because NI does not give access to the error handling.  They should not assum that the program have to stop when it get an error
Message 15 of 17
(3,046 Views)
@Tphan wrote:
Yeah,
You can post an idea/feature request here if you'd like:
https://forums.ni.com/t5/NI-TestStand-Idea-Exchange/idb-p/teststandideas
-Doug
Message 16 of 17
(3,038 Views)
Hi TPhan,
One possible way to implement this behavior is to manually set the error container of the mainsequence call step in the process model.  This can be set from within the PostStepRuntimeError callback.  This will cause the final status and sequence result to indicate an error, but still report the remaining steps.  To configure steps in the sequence to be skipped if an error occurs, you can use a precondition which checks if an error occurs.
The attached example shows this method.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
Message 17 of 17
(3,004 Views)
