I am using Teststand 3.1 and Labview 7.1.
My problem is that I have a 1D array of 6 elements in Labview that I need to receive from Teststand.
If the array size is set to variable in Labview there is no problem but if I set it to what I require ( fixed 6 ) then when I specify module in Teststand an error message appears , ' LAbview.exe has encountered a problem and needs to close '. Then I get an 18001 about ActiveX as labview has closed.
Why does this happen ?, is it a bug ?
