NI TestStand
Teststand lock when calling vb.net OpenFileDialog.ShowDialog
Hey
Im trying to use a vb.net OpenFileDialog to let the use select a file.
For example teststand calls the following vb.net function from a Pass/Fail Test step:
Public Function testfunk() As Boolean
       Dim fldg As New Windows.Forms.OpenFileDialog
       fldg.Title = "Select File"
       fldg.Filter = "(.bin)|*.bin"
       If fldg.ShowDialog = Windows.Forms.DialogResult.OK Then
           Return True
       Else
         Return False
       End If
End Function
The problem im having is that teststand locks at fldg.showdialog without showing the dialog, the only way to stop the executeing is to kill the thread.
I have scaled the problem down somewhat here just to show exactly where the problem is, when i get this part working im going to save the filepath in vb and use it for some other functions.
All help is appreciated.
(4,006 Views)
Are you sure the dialog isn't just being shown behind the sequence editor window? It's probably not going to be modal to the sequence editor because it's being displayed in a different thread. You can use Engine.NotifyStartOfModalDialogEx and Engine.NotifyEndOfModalDialog, to make the dialog modal if needed.
-Doug
(3,984 Views)
Thnx.
I will give this a try when i get the time.
(3,978 Views)
