NI TestStand
Teststand memory usage
When generating results teststand gradually uses more and more RAM. This happens when I generate a .tsr aswell as ATML(desired format). When i dont have any results being recorded the problem disappears, despite the same steps being executed. This indicates that it is the report generator that is causing the problem.
I have the following settings:
 - Model options
>> Discard results... [checked] (results are not being used anywhere else, other than default report generation)
 - Report options(for ATML)
>> Append If File... [checked]
>> On-the-fly reporting [checked]
>> Only display Latest results... [checked]
>> Processing interval: 9.50 Automatically tune interval [checked]
>> Maximum number of results: 30
Im using teststand 2012.
Please help!
Alex
Message 1 of 8
(6,055 Views)
Alex,
is this an observation or is it a problem (so running out of memory after some time)?
Do you observe this behavior also for other report formats like HTML/ASCII?
@Alex Haak wrote:
[..]When i dont have any results being recorded the problem disappears, [..]
Do you disable result recording or simply disable report generation?
Is the behavior observable with any sequence or is it connected to a specific one?
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(6,053 Views)
This sounds like you are disabling results when you don't have reports.  Basically, the Results array is increasing in size for each step that has a result is ran.
Message 3 of 8
(6,050 Views)
This is a problem. Currently the RAM is running out after approx 14hrs and it needs to be able to last 72hrs.
The same happens with HTML, at a slower rate.
I disabled report generation rather than just disabling results.
Message 4 of 8
(6,048 Views)
Hi
To help narrow down this issue can you please post an example sequence file which reproduces this issue and all files under C:\ProgramData\National Instruments\TestStand 2012\Cfg\ModelPlugins
Thank you
Regards
Anand Jain
Message 5 of 8
(6,037 Views)
I dont have access to the computer right now, but i havent got any plugins and the sequence file basically has a number of dll calls and a call to another sequence which also has a number of dll calls. So im fairly sure the dll isnt leaking any memory as without report generation the problem disappears.
I seemed to have fixed the problem yesterday afternoon, but...  i seemed to have changed something because it is back!
Could it be something to do with the way i am loading/unloading the other sequence and the dll that my sequence uses?
otherwise maybe the advanced result processing options?
another problem could be that i am filtering my results... can i be sure that teststand discards the results that i am not recording?
I think these are the only things i changed.
Thanks so much,
Message 6 of 8
(6,010 Views)
Another thing could be that im not including anything under step results. Instead i am using additional results.
Message 7 of 8
(6,000 Views)
I am seeing the same issue, it appears to be something with the Number of Results but so far I have not pinpointed it to that.  Also using TestStand 2012 SP1, and started seeing the problem when we added a loop to check BITS (could add upto 430 results) depending on the Bit stream.  We are performing Thermal Testing, so it does multiple loops through the code.
I turned on Discard Results and Display only Current with On-The-Fly Reporting, but so far I am still seeing the memory usage increase.
Message 8 of 8
(5,379 Views)
