NI TestStand
Teststand parallel execution
Hello everyone! Pls help🙏.
In the test stand, I am supposed to run a seq for 4 sockets in parallel. It's is a batch process model. In the main vi. If I give seq(one thread at a time) in step setting. It takes 15secs to complete. And if changed to parallel (all thread enter simultaneously) it takes the same time. How to reduce the delay.
In the setup, we have a couple of vi which is for power up and it has a step setting of one thread only.
Thanks in advance
(1,656 Views)
Is your VI for test reentrant? Otherwise it will run only in 1 instance, meaning it will run first in the first test socket, then it will run in the second test socket,.........
Br Vagn
(1,575 Views)
