NI TestStand
Teststand run error
Have a test rig installed in a company, Just got a call and when they run a sequence file it asks for the teststand cd trying to install something. this system was working fine on friday. any ideas why the teststand would suddenly ask for the install cd, if they press cancel the system reports that it is unable to open labview.
(3,348 Views)
I've seen this happen between Labview and VB. This is a windows problem. For some reason, windows thinks it has to install something. The only way out is to go ahead and insert the install CD and let it do the install. Then it won't ask for the install CD anymore. That is until the next time windows screws up.
- tbob
Inventor of the WORM Global
(3,339 Views)
To help solve this problem,
Can you post the name of the components being installed when you insert the TestStand CD. Also if you can post the screen shots of the installer it will be helpful.
Also
What is the TestStand version that you are using ?
Was any National Instruments software/drivers installed on that machine recently ?
Thank you
Anand Jain
National Instruments.
(3,334 Views)
