NI TestStand
Teststand send me an error code -1074001424. What is it ?
Hello ,
During test, Teststand 4.2.1 send run-time error code -1074001424.
What is this error code ?
How to understand this code ?
Thank you for your help.
CB
(3,401 Views)
Do you just get the error code but no error description? If you have a description, you might preferably post it to make your question better.
On the other hand: You can search ni.com for your error code and might get an answer like this.
(3,398 Views)
This looks more like an error that would have come out of a code module than from TestStand itself. Was this returned by a call to external code? TestStand error codes are usually in the -17xxx range.
(3,383 Views)
Hi Zeblegrand,
Can you give us more details as:
- The purpose of your application (Acquisition Step, Instrumentation (GPIB...))
- Can you attached a screen shot of this message?
- Did you find where this error code is generated?
(3,369 Views)
