NI TestStand
Teststand shuts down calling c# wrapper of c-dll
i created a Wrapper dll in c# for a c-dll.
Everything is working and all functions can be called but after 4..10 executions testand stops with big error that says:
Problem signature:
  Problem Event Name:                        BEX
  Application Name:                             SeqEdit.exe
  Application Version:                           14.0.0.274
  Application Timestamp:                     53ace5da
  Fault Module Name:                          clr.dll
  Fault Module Version:                       4.8.4018.0
  Fault Module Timestamp:                 5d4a64a8
  Exception Offset:                                0035a3f8
  Exception Code:                                  c0000409
  Exception Data:                                   00000000
  OS Version:                                          6.1.7601.2.1.0.256.1
  Locale ID:                                             2055
  Additional Information 1:                 6f94
  Additional Information 2:                 6f94982914938ac345e05a421091cbf5
  Additional Information 3:                 73c3
  Additional Information 4:                 73c346c7bd00900375bf67b1a9847619
What can i do to avoid this?
I am using TestStand 2014
The C# dll is compiled using .NET Framework 4.6.1
Thanks for help
(2,290 Views)
Hello, Iknow that this post is old, but I have a similar problem,: did you find a solution?
Thanks in advance
(1,752 Views)
Hm, yes i found a solution but i cannot tell currently what i changed...
(1,743 Views)
