NI TestStand
Teststand writes Data Missing into database when processing results
Hello Forum
I have an application that runs multiple test slots in a parallel model, the results are processed by the offline processing utility later and written to an SQL database. I have a significant amount of tests in the database which seem to have all the correct test data but report "Data Missing" as UUT_STATUS. The UUT_ERROR_CODE is always zero in this case. I have looked into the tests and they all reported Pass, so i am at a loss of where this "Data Missing" originates from.
Any inputs would be helpful,
Raphael
(1,131 Views)
some more details:The Teststand Version is 2019, the UUT_ERROR_MESSAGE is empty, Test Data seems complete and within the limits
(1,108 Views)
