NI TestStand
Text Data Log
At our company, we have about a half dozen engineers who share the same development tester.  We collect all sorts of data.  Most engineers only want to display the test name and results after the normal date stamp, tester number, time, operator number etc. Unfortunately, the current setup includes Terminations, Skipped, and Done.  This makes a data log unwieldy and difficult to parse.  Is there a way to direct TestStand to save only the test name and its associated results?  We don't use Labview so a solution would have to be something in the sequence or the use of CVI.  Thanks.
Tony
(2,848 Views)
I just made a custom report generator with LabVIEW.  I think there is a CVI example that you could start from.
(2,829 Views)
Would you be so kind to share those?  Thanks.
(2,805 Views)
Hi Tony
Check out the Result Processing... options in the TestStand Configure menu (see capture below).  It gives you some predefined Result Filtering Expression: options but allows you to modify/define your own.
Steve
(2,761 Views)
