NI TestStand
The ListBarPages object may be missing the "item" field in .net
I have my activex object.
axListBar
under axListBar.Pages.
"Count" exists, but "Item" does not show up. I have been able to access this through CVI so it should exist in .net. How can I access it in .net?
On another note, I also noticed that for the sequence context that both RunState and TestSockets are missing, however, I was able to access them through AsPropertyObject.
(2,823 Views)
Use indexers, e.g. [1], for getting the item.
You are correct that you need to get the RunState property through the PropertyObject object rather than the SequenceContext object.
Allen P.
NI
(2,815 Views)
