NI TestStand
This node has experienced an unexpected error. Please redrop the node or contact National Instruments.
well the  subject  says it all.  I added the error to the subject   so that ist helpfull to others also in future.
Issue at hand:
well am trying  teststand deployment,  my Project has classes,  TDM  files.
So that I    can   Write to   tdm file I had to install   "NI USI 2.0.0"   thr  the  teststand Installer.
TDM write seems to genrate no error  but  my other labview  file   with a   TIMED LOOP   generated error.
the XNODE  issue   is  complicated
 has any one have similar isssues
(4,680 Views)
can you explain in more details the problem description?  Please attached if possible Screenshots.
(4,611 Views)
