NI TestStand
Time stamp & array passed in a cluster through DLL are not accepted by Teststand
I am trying to pass  Timestamp & array data [string array]   in a cluster  from DLL  is not  getting recognized by testsand.
The action module (DLL)  Output (cluster)  generates   error "System Level Exception.[Error Code: -17502] "
the png file shows the cluster
I spoke to NI support & they  suppose that its time stamp that generates error
but some fields (numeric, string) i am able to read
(4,509 Views)
Hello aparab,
here is a link to another forum, which solves your issue:
time stamp, data type for dll:
http://forums.ni.com/t5/LabVIEW/time-stamp-data-type-for-dll/td-p/1085375
to summarize:
there are two possibilities to pass a cluster with a timestamp from LV to TS:
1. use a string for the timestamp, although a numeric double might be easier to work with in TestStand
2. use packed library
(4,404 Views)
thnks   Richard
(4,402 Views)
