NI TestStand
Timed Interrupt Test
I am using TS to test software timing requirements. I would like to have an interrupt in TS so that I could execute code depending on how long the the Unit under test has been running. I think I can use what is called the module time for this but I don't know how.
This is what I want to do...
1)Run ARINC for x seconds (according to the unit, not real time).
2)Check output
Currently I am breaking at points in the software and checking the system timer. The problem with this is that I can overrun the timing requirement because I am breaking every 250ms. So if I am shotting for 5 seconds I sometimes get 5.135 seconds.
Thanks for any help,
Pat
(3,367 Views)
Hi Pat,
One approach you could take would be to call a module asynchronously at the beginning of the test that constantly monitors the time status on your unit, using shared memory space such as a notifier to allow your main code to query the time status before deciding which action to take. This way, you can check the time more often since you will have a separate thread dedicated to managing the timing.you can implement the timing in a new thread by calling the module in a subsequence, then calling that subsequence in a new thread.  Let me know if you have any other questions!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,334 Views)
