NI TestStand
Tracing enabled
I' have a question. If I enabled tracing and the sequence is running, then the grew up test time is the only change or are there other changes? I think wait times, step run time etc.
Thanks for your help forward.
nkohler
(3,690 Views)
The difference is the time it takes to refresh the SeqEditor or Operator Interface during each step execution.
Your Steps' code module will run the same, Any Waits will wait the same length of time.
Regards
Ray Farmer
Regards
Ray Farmer
(3,680 Views)
Thanks the quick reply
nkohler
(3,667 Views)
I have an other question. If I run the sequence without tracing enabled then the boards failed, when I retest they with tracing enabled some boards passed.  May cause the different the tracing enabled or shall I be looking for the mistake somewhere else? Thanks for your help again.
Best Regards nkohler
(3,657 Views)
I can only guess here, but probably you are not allowing enough time between setting some stimuli and taking the measurements.
Regards
Ray Farmer
Regards
Ray Farmer
(3,648 Views)
