NI TestStand
Tracing
Quick question:
I would assume that a sequence would have a faster execution time if tracing is disabled vs. tracing being enabled. Is this true?
If it is the case, I'm not sure why my sequence test time is showing otherwise.
I am aware that when tracing is enabled, there's a slider that we can use to set the speed; however, does disabling the tracing defaults to a slower speed than the slider put on the fast?
I'm trying to follow this method basically (here), but I'm not sure why disabling tracing is just making my sequence go slower.
(3,448 Views)
Can you show this result?
Disabling tracing removes a static delay between steps hence speeding up overall test execution on a "number of step" basis. the slider simple modifies the length of the delay.
I've never seen a test slowing down when disabling tracing.....
Norbert
Expert: Geometry
(3,431 Views)
Yes. The first 5 are values with Tracing enabled and the one follows are with Tracing disabled.
All test are done withe the same unit and it's passing the same tests.
Maybe it's a setting that is causing this.
I can only send snippets of the file, but let me know if you require further information.
(3,429 Views)
Are this in units seconds?
Can there be timeout issues if tracing does NOT slow down execution?
Norbert
Expert: Geometry
(3,423 Views)
Hey Norbert,
Sorry for the late response but yes, the units are in seconds.
I don't think the execution have timeouts or is waiting for function to process.
In any case I'll run more test and see what happens. I do notice inconsistencies such that tracing disabled does produce a faster time. It is not my much though.
I'm most likely to try and do more than 5 runs on each and see what the average is.
(3,405 Views)
Fully agree with
(3,401 Views)
Ok thanks everyone for the response.
But I'm not sure what caused the result to be the opposite.
I ran a couple of test yesterday and it does seem to be faster now when disabled.
It was just interesting on how execution time seemed to increase when tracing is disabled  ... hmm
(3,391 Views)
