NI TestStand
Training for test stand
Need to go from zero to hero when it comes to Test Stand in the next two weeks!!!!
Investigations are on going to get onto an NI course but in the time between what can you advise as to get running on Test stand?
A lot of DLL calls and c types function used in the sequences.
Any advice or direction would be much appreciated
It would appear that thers is some LabView also but that is another days work which will get addressed it time
Simon
(3,354 Views)
Go through the Using Labwindows\CVI with Teststand manual that is shipped with TestStand.
Regards
Ray Farmer
Regards
Ray Farmer
(3,350 Views)
Hi There,
The manual is a great place to start.  Another might be the NI webpages.
http://digital.ni.com/express.nsf/bycode/exp29f/
There are a number of one minute demonstrations that may help you understand TestStand and how to use it.
I would however try and get on a course as soon as possible.  It s a great way to get all the knowledge you need to get cracking on TestStand sequences.
Good luck
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,326 Views)
Thanks for the replay's.
The web is good for TestStand 4.0 by the look of it but we have 2.0.1 and 3.1 so we are some what behind with no plans to come up to date.
So the need to to learn on these!!!
Any other thoughts or direction?
Simon
(3,298 Views)
