NI TestStand
Transferring Report Options between two computers
I have set up report options on one computer and I want to have the same settings on the other. Is there any way I could transfer/copy those report options from one computer to another? Actually I'm doing it manually but I really hope that I could do it by copying some files or maybe programmatically...
(3,336 Views)
Accepted by topic author pitol
Are your two systems development systems or target systems.
If they are target systems, include the Report Options Configuration file in the deployed image.
If there are development systems, leave the Report Options as default settings and make sure you use the ReportOptions Override Callback sequence to setup the ReportOptions for your test requirement.
Regards
Ray Farmer
(3,331 Views)
How could I miss ReportOptions Callback? Smiley Wink
Thanks Ray!!
(3,329 Views)
