NI TestStand
Traverse Variables in FileGlobals
Is there a way to traverse all the variables under FileGlobals as key and value pair? I'm having trouble finding a function that will give me all the variable names for PropertyObject.
- Jimmy
(3,696 Views)
First of all I'm confused by your "key and value pair" statement.  What did you mean by that?
Secondly you can use: FileGlobals.GetNthSubPropertyName("", N, 0) to get the name of the sub property.  N is the index.
Here is from the help:
GetNthSubPropertyName Method
Syntax
PropertyObject.GetNthSubPropertyName ( lookupString, index, options)
Return Value
String
Name of the subproperty the index specifies.
Purpose
Returns the name of a subproperty within the property the lookupString parameter specifies.
Parameters
lookupString As String
[In] Pass an empty string to denote the PropertyObject to which the method applies, or pass the name of a subproperty within the PropertyObject. Refer to Lookup Strings for more information about the strings you can use.
index As Long
[In] Pass the zero-based index of the subproperty.
options As Long
[In] Pass 0 to specify the default behavior, or pass one or more PropertyOptions constants. Use the bitwise-OR operator to specify multiple options.
GetNumSubProperties is also a good method to use.  Just call FileGlobals.GetNumSupProperties("").
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,685 Views)
I threw together a simple example to recursively get all the children of fileglobals.
jigg
CTA, CLA
testeract.com
(3,682 Views)
Hello Jigg, thanks for responding. Can you convert the sequence file to 4.2.x format?
- Jimmy
(3,660 Views)
Accepted by topic author jxjimmy
Here you go.  Let me know if that works.
jigg
CTA, CLA
testeract.com
(3,654 Views)
