NI TestStand
Two New TestStand NI Labs postings!
Hello all!
I wanted to let everyone know that we recently posted two new TestStand projects to NI Labs that you might find useful.
Command Line Deployment Tool – This project provides instructions on how to pass command line inputs to the TestStand Deployment Utility (TSDU) so customers can programmatically create deployments with TestStand 2012 and later. This can enable users to create automatic nightly builds off of source code repositories when working on projects with multiple developers.
Text-based Sequence File Format (TSText) – This project allows users to create TestStand Sequence Files in a JSON-like text format rather than creating them in either the TestStand Sequence Editor or an Full OI. TestStand will then translate the text-based format into a true sequence file before running.
Additionally, if you weren't already aware we have had what was called the "TestStand Toolkit for Large Application Development" on NI Labs for some time. We've recently split these out into the two separate pages below:
  • TestStand Sequence File Viewer – This tool lets users open and explore TestStand sequence files that have been saved in the XML format on machines that do not have TestStand installed
  • TestStand Type Differ – This tool allows developers to determine and resolve differences in types between any two TestStand files
Check them out and let us know if you have any feedback for us!
Lars
Message 1 of 1
(7,772 Views)
