NI TestStand
Two Reports
I am sorry about that I meant Single Pass.
If I do what Caroline suggested I still get only one .html report.
Any idea wht I could be missing.
Sumit
Message 11 of 16
(2,174 Views)
Hi Sumit,
The file that I posted before was only for Test UUTs. If you make these same changes in the Single Pass sequence it also works. I am attaching another file with these changes made. You can run it by selecting Execute -> Single Pass or Execute -> Test UUT. I have tested both of these and see they work when run in this manner.
Caroline
Caroline Tipton
Data Management Product Manager
Message 12 of 16
(2,168 Views)
I needed exactly what I found here in this thread and I made these modifications to my Teststand 3.5 sequ. model. The only issue was that the report would not be shown correctly since the ActiveX module tried to open the .txt report as HTML or XML. So I added a local variable that stores the original HTML/XML report filename and added a step to restore it before showing the report.
Message Edited by Stephan K. on 03-27-2006 10:58 AM
Message 13 of 16
(2,072 Views)
Unfortunately, this only works for Test UUT so far. When I run a single test, the result viewer will show me the content of the "tempresult.html" file, although I don't use a temporary report and both ( HTML and txt) result files exist. Where does teststand create the tempresult.html file? And how can I disable it in Single Test?
Message 14 of 16
(2,042 Views)
Sorry, I mean "Single Pass" and not "Single Test" .
Message 15 of 16
(2,032 Views)
I fixed the problem by adding a step that loads the report from the harddisk.
Here is the final sequence:
Message 16 of 16
(2,029 Views)
