NI TestStand
Two Teststand sessions opened - Popup with changed StationGlobals
i am running teststand in a custom GUI where a executing file is writing values to StationGlobals..
When i then open parallel the normal teststand-editor to simply edit another sequence (not the parallel running) then i get the attached popup.
I am not sure if this popup is coming from the:
a) running Teststand in the Gui which is executing a sequence or
b) from the not running "normal" teststand where only a sequence file is opened
What is the correct selection in the popup so that the running/executing teststand does not lose any values in StationGlobals? Is there a way to set this selection as default?
Thx
(2,551 Views)
StationGlobals variables are saved in an ini file and are accessible to every sequence file on a station. Since you are writing to the StationGlobals in your custom GUI these changes are also noticed by the TestStand Sequence Editor. The engine has a mechanism that notifies the user of changes made to ini files.
Which UI throws the message and what exactly are you doing? I could provoke that message only under these conditions:
1. Changing the StationGlobals.ini from the Sequence Editor
2. Running a sequence file that modifies the value of a StationGlobals variable in the custom GUI.
The message is thrown by the custom GUI when exiting the application.
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(2,498 Views)
