NI TestStand
Two different licenses on the same HW
I would use two end-user license of different type (one Test Stand Development System and one  NI Automated Test Software Suite)  on the same HW ( PXI with embedded controlloer). Is it possible?
Thank you in advance
(2,773 Views)
Is there a reason you are doing this?
In short it is possible to have separate licenses on the same system, however the Automated Suite will activate the TestStand Development System as well. So it is unnecessary to have both.
Nico
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(2,753 Views)
yes I understand that  the Automated Suite will activate the TestStand Development System  but I need that the user with the Development system license does not have access to features that just belogn to the automated suite. But I don't know how to switch between licenses.
Thank you for your reply.
Francesca
(2,751 Views)
Unfortunately I don't believe you can. Not with a stand-alone license like that. If it something you do need to do, I'd recommend talking to your local NI support team to see what work-around can be done.
Nico
Nico
Systems Engineer
(2,736 Views)
