NI TestStand
Two reports per test
I have a need to produce two different reports per test. One a simplified pass / fail document, and the other our normal detailed text report.
I am looking for advice how to approach this.
I can add steps to print the pass fail report at the end of each section, but when I tried following an example to print to a word document it failed for lack of Microsoft Word, the company use word365.
Is there a simple way to print to a pdf from a step?
I am using Teststand2020.
Thanks.
David
(1,558 Views)
Just set up 2 reports in the plugin configuration and have one be XML and the other HTML(PDF) but not log any steps.
Shows 2 reports setup:
How I set up the HTML to print to PDF and only show pass/fail information:
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,535 Views)
Thanks, I had missed the simple option.
I had not seen the option to filter the results on a function. I should be able to use that to generate occasional pretty results during the test.
I will do some experimenting and report back.
David
(1,527 Views)
I have tried this and am having some success.
I have created a status filter that looks for pass or fail (not passed / Failed) and am adding action steps to the sequence to report previous step passed or failed at a few critical points.
One annoyance is that it is still creating a XML version of this report, so I now have 3 files my text file the pdf and this extra XML.
David
(1,494 Views)
The PDF will generate an HTML file.  What is in your result processing configuration?
jigg
CTA, CLA
testeract.com
(1,486 Views)
I would like to avoid having the html and the pdf reports both saved. At the moment the results folder has the 2 mixed together.
I need to do some work on the formatting of the reports but I would like to get the system working with the default layout to start with.
This is the config screen.
(1,481 Views)
