NI TestStand
Two step serial number verification in PreUUT
Hello all,
I am using sequential model and trying to modify PreUUT so that I can implement two step verification for serial number using "Do While" loop with Message Popup. e.g. if the operator doesn't enter matching serial number it will loop again unitl matching serial number are entered in both popup entries. The issue is I could not save this, serial number, into global variable and print it in the report. Any help would be appreciated. Below is the example of my implementation within PreUUT;
Do While (RunState.Sequence.Main["Message Popup1"].Result.Response) != (RunState.Sequence.Main["Message Popup2"].Result.Response)
Message Popup1 -- "Enter UUT Serial Number"
Message Popup2 -- "Re-Enter UUT Serial Number"
End
f(x) Statement -- Parameters.UUT.SerialNumber=locals.SerialNumber
using NI TestStand 4.2
(3,772 Views)
First of all why would you need to put both on the Report?  If they are forced to enter the same serial number then it seems to me that you only need to display one of them.
Secondly- See my example.
Hope this helps
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,762 Views)
