NI TestStand
Type Conflict error for "CommonResult"
I am Getting TypeConflictError for "CommonResults" under StandardType on opening the sequence file.
what counld be the possible cause for this error?
I am not altering the type in my sequence file anywhere.
Bharathi
(3,803 Views)
What Teststand version are you using?
Dont forget it's not only the Client SequenceFile but also the Process Model sequence file.
After you tried using the Types Diff tool to identify where the problem lies.
(http://forums.ni.com/t5/NI-TestStand/error-SpecifyExeByExpr-error/m-p/1124170#M28903)
This sequencefile you are opening, do you know where this sequence file has come from?
Regards
Ray Farmer
(3,798 Views)
Hi Ray Farmer,
    Thanks for your response.
    i am using TestStand Version 4.2.1
    This Sequence file is created by me and i haven't tampered any of the types in it.
    Can you please tell me about "Types Diff tool"
Bharathi
(3,794 Views)
You might have a type virus. I can't remember exactly how it works, but since commonResult is in every sequence, you start out with some different version in a sequence somewhere, and it gets propagated to other sequences automatically in some cases. If this is the case then you have to run a tool to get rid of it. I would contact NI tech support. There might be an app note about it on NI.com.
cc
(3,778 Views)
 Thanks for your responase.
 Can someone tell me the actual version of the type "CommonResults" shipped with TS4.2.1.
Bharathi
(3,767 Views)
Need some help on this too!
(2,235 Views)
