NI TestStand
UI Message for Execution List Bar selection
I'm working on a LabVIEW UI that contains TestStand controls. Is there any UI message code that will be triggered when I click and choose one of the executions on the Executions List bar (upper left side)? Basically, using the UI message event callback, I want to display different VI front panels (inserted into the sub panel on the right side) for different executions that I choose.
Thank you.
(2,574 Views)
Accepted by topic author Chickentree
There isn't a UI Message code for this, but you should be able to register for the ExecutionChanged Event and get something similar.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,555 Views)
