NI TestStand
UIMsg_RefreshWindows is taking too long to execute
Hi all,
I have a Process Model sequence file that calls the PostUIMessageEx method with the UIMsg_RefreshWindows parameter on the SequenceFielPostStepRuntimeError and the SequenceFilePostStepFailure callbacks. This has been taking really long to execute (>3 minutes) since I moved to TS3.5 about a month ago. Do you guys know of any issue of this method with these particular  parameters on TS3.5? What could be causing this problem?
(3,109 Views)
Hi, <<...
There is nothing out of normal among your parameters. The synchronize option you selected is going to make the method wait until the operator interface process the message. So it depends on what you put in your UI message event handler. I'm not aware of anything related to this method itself that could cause this slow execution behavior. If you could send us a simplified version of the project, maybe we can further investigate the issue.
Song D
Song Du
Systems Software
National Instruments R&D
(3,061 Views)
