NI TestStand
USB-6525 how to configurate in Teststand?
Hello, i need to comunicate whit this card USB-6525 and i dont know how. Can you explain me, how i can configurate usb-port in the NI 6525 for Teststand? or any solution?
(1,115 Views)
Hi, There are multiple ways to communicate with USB 6525 device from Teststand. As you might know, TestStand is a Test management software so it can't communicate with your device directly. You will have to write test code modules/programs in one of the following programming environment and call those code modules/programs in TestStand to automate your tests.
  • LabVIEW/CVI/NXG -> TestStand
  • Python -> TestStand
  • .net -> TestStand
  • C/C++ -> TestStand
NI does not recommend calling functions in hardware driver DLLs directly from TestStand. Instead, NI recommends that you create a code module from a supported application development environment (ADE) to interface with the driver and acquire data. You can then call this code module from a step in a TestStand sequence.
NI recommends this approach for the following reasons:
  • Writing a code module in a supported ADE provides access to driver wrapper code, such as the LabVIEW NI-DAQmx Library, which is fully documented and supported.
  • Using a code module can help modularize components of the test system and reduce unnecessary complexity in a TestStand sequence. For example, instead of creating multiple TestStand steps that interact directly with a hardware driver, you can create a single code module that configures the hardware, acquires measurement data, and returns a numeric result to TestStand for evaluation.
Refer to this link to get started - https://www.ni.com/pdf/manuals/373436f.pdf
Dharani | CLA | CTD
(1,039 Views)
