NI TestStand
USB8506/2
Hello
For an application using C# and USB8506 component with the "nixnet.dll"
I have to send master request frame onto the lin bus and then read the slave response,
to make that i use the sequence bellow
nxCreateSession("database", "Cluster", "frame0,frame1", LIN0,nxMode_FrameOutStream, m_OutputSessionRef);
nxCreateSession("database", "Cluster", "frame0,frame1", LIN0,nxMode_FrameInStream, m_InputSessionRef);
nxWriteFrame(m_OutputSessionRef, l_OutputBuffer, 24, 0);
nxWriteState(m_OutputSessionRef, nxState_LINDiagnosticScheduleChange, sizeof(uint), nxLINDiagnosticSchedule_MasterReq);
nxWriteState(m_OutputSessionRef, nxState_LINDiagnosticScheduleChange, sizeof(uint), nxLINDiagnosticSchedule_SlaveResp);
nxReadFrame(m_InputSessionRef, l_InputBuffer, 24, 5.0, l_NumBytes);
nxWriteState(m_OutputSessionRef, nxState_LINDiagnosticScheduleChange, sizeof(uint),nxLINDiagnosticSchedule_NULL);
nxWriteState(m_InputSessionRef, nxState_LINDiagnosticScheduleChange, sizeof(uint), nxLINDiagnosticSchedule_NULL);
nxClear(m_OutputSessionRef);
nxClear(m_InputSessionRef);
When I start my application and "NI-MAX" together all is good
but if I stop "NI-MAX" I have no response (nxReadFrame end with error (Hex 0xBFF6300A)).
Where does this problem could come, do we have to use temporisation between the dll function....?
(3,034 Views)
Hello, I have a similar problem with this module, does anyone have an idea ?
(2,997 Views)
I try other test changing the USB8506 with a PCI8516 but I have the same problem,
I add "nxReadState(nxState_LINComm)" between each functions but no error are returned
Is there a mistake in my sequence...
(2,923 Views)
You probably want to repost this to the hardware forum board to get some response as this is the TestStand board!
Regards
Ray Farmer
(2,921 Views)
Accepted by topic author nite
Starting the input_session manually(nsStart) at the beginning solved the problem...hope this will be usefull for other!
(2,881 Views)
