NI TestStand
USRP 2942
I am a USRP 2942 user. I want to use matlab language with usrp.
So can it use matlab code?
how do I get matlab example code with usrp 2942
(985 Views)
You can use the "USRP Support from Communications Toolbox" under MATLAB if you are used to a MATLAB.
https://www.mathworks.com/hardware-support/usrp.html
You can use a MATLAB script node under a LabVIEW If you use a MATLAB code with LabVIEW.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019XaYSAU
(931 Views)
