NI TestStand
USRP stopped loading firmware & FPGA image
Hi everyone!
Could you, please, help me with the issue encountered a while ago. We've been using NI USRP 2901 for a long time, but since last Friday it stopped to download firmware&FPGA image during initialization.. It's really strange cause we've not changed anything and also there is the second USRP of the same setting and nothing changed there.
Here are the pictures - correct and dodgy one - which show difference: no FPGA image and firmware images get activated during USRP start on dodgy USRP.
Has anyone else faced anything like that? Could you give any advice, please? Would appreciate that much.
Br, Demetrio
(1,361 Views)
Hi Dmitry_Slesarev
There are 2 options that I think will help in this case.
  1.  Try to perform in a different PC, to make sure if problem comes from your PC or there is another source.
  2. Uninstall / reinstall your drivers. (specifically, USRP hardware driver)
Regards)
_______
Best way to thank is to give Kudos / Mark as a solution.
(1,145 Views)
