NI TestStand
UUT Result = Failed, but all steps = Passed?
I've allowed some of my steps to be repeated if they fail, but not using the loop function. If the step gets recorded as a fail, I use the SequenceFilePostStepFailure call back to roll back a step and repeat it if the user wants to.
This all works fine, but the result recorded ends up like this:
How do I stop the UUT from recording a fail even though all steps pass?
(3,773 Views)
Accepted by topic author Lbee11
The RunState.SequenceFailed property is set if the "Step Failure Causes Sequence Failure' property is enabled in the Run Options section of the step settings. If you're manually changing the step status, you should also set the SequenceFailed property appropriately. Try something like 'RunState.Caller.RunState.SequenceFailed=False' in the SequenceFilePostStepFailure callback.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,745 Views)
Do you find root cause of this issue?
I will appreciate if your share your findings, thanks.
(2,868 Views)
