NI TestStand
UUT Result log in SQL database?
Hello All
I am facing a requirement where i want to log results of sequence execution[only the complete seq result and NOT step results] to SQL database BUT as and when the UUT_ID varies the entry should be made into a new column with the same name as UUT_ID. As of now whenever i execute a sequence with different UUT_ID, a new row gets added as a result.
Please reply back with your suggestions asap, as this very urgent for me 🙂
Regards
Nitin Goel
(3,657 Views)
I don't understand the schema you are trying to implement. If you want a new column for each UUT in the step results table, how can you possibly differentiate between each one when you query the database? A new row is the expected and normal behavior. I don't think I have ever heard of such a database design as the one you want to implement.
(3,652 Views)
Thanks for the information.
Actually, i want to get a new column added for test result of same sequence whenever it is executed with a different UUT_No and it is primarily because i have thousands of test cases in my test system and i want it in format as below:
              Build1       Build2        Build3
Test1      Passed     Passed      Passed
Test2      Failed       Passed      Passed
and so on.
(3,649 Views)
But in my opinion, that's just a way to display the results - not a way to store the data. I also have thousands of test cases and tens of thousands of different UUT each month. Each UUT has a separate record (a unique row) and yet if I design a proper query and report format, I can show the results exactly like you have. The design of a relational database should not be the same as a report design, imho.
A database is designed to have unlimited rows (dependent only on storage space). I'm not sure a db can have unlimited columns. That would be something you could check with your dba. Dynamically adding a new column and doing an update to an existing row would probaby be much slower than just doing an insert.
(3,644 Views)
