NI TestStand
UUT serial number scanned at beginning of sequence, what variable / parameter is it stored?
I've been seeing posts stating that this data gets stored in the "Runstate.Root.Locals.UUT.SerialNumber" parameter, but whenever I call this parameter in any expression I get the "Unknown variable or property name" error retruned back.
Where is UUT serial number stored? I need to access that parameter as I need to write it into a text file for programming purposes later in the test sequence.
JD
(1,311 Views)
Accepted by topic author James_D22
You will see this variable only if your sequence is run with the TestUUTs Entrypoint Run any sequence using this entry point, have a breakpoint somewhere in your MainSequence and you should be able to find it on the Variables Pane
(1,297 Views)
Setting the breakpoint helped. I was calling it incorrectly and like you said, the actual variable doesn't appear unless during runtime. Thanks for pointing that out.
(1,247 Views)
