NI TestStand
Unable to See Logged Value in Test Report
I am new to Test Stand, and I have read a lot of posts about logging, but I can't seem to make it work. I have a sequence that calls a method from my C# DLL called getValue() to return a double. When I check the "Log" box for the Return Value of the method call, the report does not show the return value (or anything else).
I am able to store this value in a local variable and see the value if I set a break point after the step and then look at the current value of the variable, so I know the method is working from Test Stand. However, if the sequence ends it resets the value of the local variable back to 0.
"Disable Result Recording for all sequences" is not checked in the station options, the sequence options, or the step options. Please help.
(2,444 Views)
Accepted by topic author bpo
Solved it. Under Configuration -> Result Reporting -> make sure result filtering Expression shows All Results.
(2,432 Views)
