NI TestStand
Unable to call Labview code module packed in lvlibp
Hi all,
I'm migrating my development from TS2019 to TS222.
I get an error on a san action step which call a VI packed in lvlibp file.
Error message says :
"TestStand cannot browse into a LabView packed project library file. Ensure the file is a valid .livlibp file. You must use LabVIEW 2010 or later to browse into LabVIEW packed project library files".
So I installed Labview runtime 2010 SP1 without success (same error).
On my others PCs with TestStand 2019, it's working and I don't have labview 2010 but Labview 2018.
So I tried Labview 2018 with the same error.
Thanks in advance for your help
(961 Views)
What version of LabVIEW was the PPL built in?  And was it built with the ability to use a newer Runtime Engine?
(949 Views)
