NI TestStand
Unable to load Labview project
Hello
I am using TestStand to run a number of Labview Tests but whenever I start to load the labview file, the following error occurs
"Unable to load LabVIEW project. The LabVIEW project or one of its dependencies might be missing. "
You can see this error in the image file attached below.
Omer Bashir
(4,382 Views)
Hello Omer,
I'm curious if you have NI 488.2 driver downloaded?
http://www.ni.com/download/ni-488.2-14.0/4802/en/
Also, I'm sure you already know this but here is a good resource deploy LabVIEW code modules in TestStand:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2pdCAA&l=en-US
Jonathan R.
(4,330 Views)
