NI TestStand
Unable to load VI with LabVIEW Run-Time -VIs are missing
i have a problem with loading the VIs in TestStand 2016 RunTime mode.
There are vor exampe the DAQmx Stop vi missing.
What i have to install or to do, that i can run the VIs in RunTime mode? Is it necessary to install LabVIEW2016?
Thanks for your help
(2,459 Views)
Have you checked if you have DAQmx driver installed in the machine? This is required if any of the VI code modules in your teststand sequence have used DAQmx driver functions.
You can check if you have DAQmx by using the steps in this KB article:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8dMSAS
Thanks and Regards,
Supreeth.K
(2,433 Views)
