12-10-2014 02:23 PM
Any help greatly appreciated!
I would like to merge records from a crosstab query but am getting an error. Any suggestions?
Situation
The following results are queried from our TestStand results database (mdb).
We have the following CrossTab Query output. See how the data is scattered over two records for the same circuit?
2 Crosstab Results By Test |
UUT_RESULT.ID |
STEP_RESULT.ID |
CircuitProp |
CurrentProp |
VoltageProp |
82 |
3194 |
1 |
10 |
82 |
3195 |
1 |
100 |
82 |
3196 |
2 |
11 |
82 |
3197 |
2 |
110 |
82 |
3198 |
3 |
12 |
82 |
3199 |
3 |
120 |
We’d like to merge these records like this:
2 Crosstab Results By Circuit |
CircuitProp |
CurrentProp |
VoltageProp |
82 |
1 |
100 |
10 |
82 |
2 |
110 |
11 |
82 |
3 |
120 |
12 |
The Error:
Unfortunately, when I attempt perform a query of the above crosstab query results, an error occurs:
The Microsoft Access database engine does not recognize '[2 Crosstab Results ByTest].[UUT_RESULT].[ID]' as a valid field name or expression.
Thoughts:
I suspect Access does not like the "." in "UUT_RESULT.ID". That is a result of the crosstab query, however, and I can't see how to change it.
Solved! Go to Solution.
12-11-2014 07:53 AM
Hello flundquist,
You are most probably correct in assuming that the peroid (.) in the name of the column is the problem. See this link.
I am not very familiar with CrossTab queries, but i have read that it operates on a single table. If this is the case, i am assuming you might have created a join of STEP_RESULT and UUT_RESULT tables first, so as to get the single table to execute a Crosstab query. If so, isn't is possible to rename the columns as you create the join?
I have also read that you can modify the column headings for a CrossTab. Please see these links: youtube, msaccess.
Unfortunately, I could not verify that this works but i hope it helps.
Tinu
12-15-2014 01:21 PM
That worked! Thanks TInu!
