NI TestStand
Unable to read data in ResultList through SequenceFilePostStep callback
I am working on an application where I need to access the ResultList variable from Test stand into Labview and create my own customized report. I require data like StepName, Numeric value, Status, Loop index, NumPassed and NumFailed, etc. I have looping in each step and basically need to read the ResultList array after each step (results of all the loops in a step).
I have implemented the SequenceFilePostStep callback in the teststand and UI message event in Labview to read the results. But, I am unsuccessful in reading any of the data, I get an error saying unknown variable.
The expression to read the step name;
RunState.Root.Locals.ResultList[0].TS.StepName
This is the SequenceFilePostStep callback;
The error I get.
Callback VI to read the UI message
However, when I give the same expression as a step (Message Popup) in the sequence, I do not get the error. It pop ups the step name perfectly.
What am I missing? why is the expression failing in the callback and not in the Message Popup step?
Any suggestion would be of great help.
(648 Views)
Hello.  My guess is when you run 'SequenceFilePostStep'  at that point the result has not yet been posted in the ResultList hence the expression 'RunState.Root.Locals.ResultList[0].TS.StepName' is not yet valid.
En
I used the SequenceFilePostResultListEntry callback and the above expression worked.
~Teds
(599 Views)
Good point! The ResultList entry only exists after the  SequenceFilePostResultListEntry.
Yet I have to admit that I wasn‘t able to find a comprehensive list / description of the when the according callbacks occur in respect to each other…
(586 Views)
Hi Teds,
Thanks for the reply.
I used the ResultObject to get the final result list. Although I wanted to display the result after every execution of a step but I guess I am ok with the final result which is available in the result list after the end of sequence execution. I am using this to generate the final report.
Thanks again for your idea.
(572 Views)
