NI TestStand
Unexpected terminated
Hi all,
In production, we are running sequences in parallel in a custom OI (we don't have the source code).
Since severals months, some times sequences finish with "terminated" state without error and nobody terminate these sequence manually.
And I don't see with these sequences are terminated.
How can I debug and investigate this issue? How can I find the root cause? Log file? Trace ? ...
Thanks in advance for your help
(190 Views)
Basically, there's two main locations from where termination can occur.
  • SequenceFile
  • OI
Since you don't have access to the OI code.... do you see any test reports which have which show terminated as a result?
(suppose you use the standard reporting)
(172 Views)
In the report, I see that the termination occurs in the sequencefile prestep callback.
Unfortunatly, I disable report for the sequence call by this step, So I don't see the root cause.
Does the only solution be activating report in this sequence?
Thanks again
(139 Views)
At least it'll lead you closer the origin...
Before doing so, you might want to analyze what the code in teh callback actually does.... might be a hint
(135 Views)
