NI TestStand
Update Station Globals from CVI UI
Hi, I am having a requirement such that i need to update a station global variable to true or false based on the click on a button present in User Interface. My Setup: Labwindows/CVI 8.5 TestStand 4.2.1 XP Please point me to the basic programming examples of the CVI based User interface. Regards, Ramjee
(3,494 Views)
The CVI User Interface that ships with Teststand can be found in the directory ...\Program FIles\National Instruments\TestStand 4.1.1\UserInterfaces\FullFeature\CVI. Mods will be needed to send the value to TS which can then change the station global file or write to the global file from CVI UI.
CLD
(3,354 Views)
Are you sure you want to change the StationGlobal file or just change an actual StationGlobal variable. When the UI closes and shuts down the TestStand engine the StationGlobal file is updated automatically.
Regards
Ray Farmer
(3,322 Views)
