NI TestStand
Update Teststand 2013 -> 2014: Convert Old Macros to New Macros
after an update from Teststand 2013 to Teststand 2014 (32-bit), update sequence files (Sequence File Converter) and  migration with TestStand 2014 (32-bit) Migration Utility I get an error if I start teh old sequences.
An error occurred in c:\Programme\National Instruments\TestStand 2014\Components\Models\ModelPlugins\NI_ReportGenerator.seq
Sequence: Model Plugin - Initialize
The problem are the two lines with "Convert Old Macros to New Macros". The name of the function is corrupt. What is the correct content of this field?
At the moment I skip these two lines without a visible problem.
Thanks, Thomas
(4,512 Views)
Attached is a screenshot of the function.
Could it be that you need to use the new version of modelsupport2.dll?  Maybe this function didn't exist in the old version?
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,413 Views)
