NI TestStand
Update of Steps based on Steptypes using Sequence Adapter
in some cases i use Custom Steptypes based on Sequence Adapter. SequenceFile, Sequence
and all used Parameters are specified by the 'Edit Sequence Call' window.
Problem:
I do some changes in this specification of my Steptype (e.g. name of sequence) and save this Type Pallette with option
'Do Not Increment Type Versions'. TestStand afterwards shows the window 'Type Conflict In File' if a SqeuenceFile with
an instance of this Steptype is used and all detected changes are listed in the upper listbox of that window. Now i activate
'Use Currently Loaded Type' and 'Apply Option to All Conflicts in File' expecting that my Steps based on this StepType
are updatet with my changes (e.g. name of sequence).
The result is that, none of the changes made in 'Edit Sequence Call' window of my Custom Steptype is
updatet!
Other changes (e.g. adding a variable to the Stetype) are automaticly updatet by TestStand!
Any idea what i can do to update my Steps?
Sunny
(2,902 Views)
hello sunny,
i tried to reproduce the behaviour on my machine, but i got not the same result.
could you provide the steps i need to take to reproduce it as it is on your machine?
thanks,
regards,
robert h
national instruments
(2,891 Views)
