NI TestStand
Update user LoginName on the fly?
"but only when the test UUT`s sequence ends"
Do you mean the User: field in the status bar doesn't refresh until then, or you actually can't change the user?
If it is the former, try calling:
 ((ApplicationMgr)engine.GetInternalOption(InternalOption_ApplicationMgr)).Refresh(RefreshOption_All);
Message 11 of 12
(942 Views)
Hi Schwede,
Here's a quick example that does what James suggested.  Note that while you can run this example as-is, this example would need to be expanded upon before implementation in your application - for example, there is no checking done to see whether or not a user with a given LoginName exists, and no password checking.  It proves the concept, though.
Derrick S.
Product Manager
NI DIAdem
Message 12 of 12
(930 Views)
