NI TestStand
Update vi from file global variable
Hello everyone,
We have a sequence that change a control in several steps, without a loop.
We want to see the measure in a vi front panel, that update the result, while the sequence go.
We find the guide from ni for update a variable, and for run vi asyncrony.
But we don't understand if for every step we have to put the last/step step.result.numeric in the variable or there is a way to do with an expression in the setup at the start at the sequence one time?
In case, can you please help to understand better  how to run asyncrony or how to write the expression for make the variable equal to result?
Thank you all for the help
Giorgio
(458 Views)
Hi Giorgio,
could you re-phrase your use-case? I don't understand, what you want to achieve
(395 Views)
