NI TestStand
Updating a Teststand status bar
I am trying to understand how to update a progress bar that I want to add to the Teststand simple interface. I have been through the one example that ships with TS that shows some info on doing the job through a vi, and after a bunch of searching I have found a number of other items that seem related to this job.
Ideally I would like to build something generic (and simple) that will just show where I am in the execution of the top level main execution, maybe a percentage based on the current step index/total # of steps times 100 to get a percentage value.
Here are the items that seem like they might be related:
Under the UI messaging category there is a code called UIMsg_ProgressPercent.
Under the Execution View manager there is a NumericSource_ProgressPercent.
I can understand the UIMsg_ProgressPercent, but I can't see why it is any different than just sending a numeric value with any user configured event. Is there some inherent link to an ActiveX control on the UI?  I can place a Status Bar activeX manager control, but can't see how the link occurs. It seems like it is possible to place several status bars, so how do I link to specific one?
As for the NumericSource_ProgressPercent, what is this thing returning exactly?
Any assistance would be appreciated. Thanks!
(4,967 Views)
Hi.
You have to configure the 'panes' of the UI StatusBar Control.  Here is what I do to implement a StatusBar.
1.) Right click on the UI StatuBar control and select StatusBar->Properties...  From this window you can name all the panes that comprise the statusbar.  I will later use the 'index' of a pane to update them as needed.
2.) From the AfterUIMessageEvent Callback, I configure Event 11 to handle the progress percent update.    I have some code in my process model that updates the progress percent ( sends a UI Message ) with a new value based on the # of steps completed in the mainsequence in comparison to the total number of steps.  See attachment for the code.
I hope this gets you started.  Good luck.
PH
(4,962 Views)
Thanks PH! I think this will get me on the right track.
(4,940 Views)
I have a similar problem now, and your code works fine. But the indication of the progress should work even without this.
The ExecutionViewMgr.ConnectCaption should do the same, if I associate the CaptionSource_ProgressPercent with the right pane of the status bar. It works with the delivered fully featured UI for TS2010 SP1.
I modified it a little bit, and I expect an update on the corresponding status bar pane upon calling the Thread.PostUIMessageEx. But it won't be updated, so what else do I have to do additionally to call the ExecutionViewMgr.ConnectCaption ?
MB
(4,478 Views)
