NI TestStand
Urgent -How to get Assembly Path in a variable?
Hello
I am having a step where i need to send accros the assembly path  as a function argument to my .Net assembly.
Example:
Consider a Action Step with .Net adapter
Lets say i have added a .net assembly for which the path is relative and NOT absolute, now i need to send this path which has been added in search directories for the local m/c as an argument of a function.
Please reply with your suggestions asap.
Rajender
(3,324 Views)
Hi Rajender,
attached you get an example sequence file that reads the latest path from the
TestStand search directories and stores it in a variable.
Regards
DianaS
(3,249 Views)
